Chad_A
- Jul 19, 2002
First off I'll admit that I'm a complete newbie when it comes to home audio, I've spend my years doing it all in the car till recently.
I picked up a QSC RMX850 for my sub not thinking of the problems I may have with running Pro amp with consumer level inputs.
Anyway my problem is that the amp clips very prematurely, I barely turn it up and it clips. I've tried running it from my receiver, a bookshelf system, and even direct from my soundcard just to see what was going on.
I'm guessing the problem is I have too low of a signal voltage causing the amp to clip when I hardly turn the gain up at all. I've heard something about my problem being that I'm using consumer level outputs (-10db) on a pro amp with +4db inputs.
If this is my problem what is the absolute cheapest way to fix this (I'm a college student and have an extremely tight budget). I've heard something about a Level Shifter then I was told a decent Direct Box would take care of the problem too....
Can you point me in the right direction? (I'd love to spend $50 or less if at all possible)
