bryanschmidty
- Jan 1, 2010
- Bryan
I am having troubles with my desired Home Theater setup and I hope someone has some insight on what additional equipment I may need, or if I am doing something wrong.
Here is my setup:
I have a Digital Lifestyles 42" 1080i HD LCD TV in my family room upstairs.
I have my HTPC with an nVidia HD 4200 card (HDMI output) downstairs
I have a Dish VIP722k DVR with HDMI output downstairs
I have an HDMI extender over Cat6 (http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042501&p_id=6177&seq=1&format=2) that sends an HDMI signal upstairs via 2 Cat6 cables, transmitting across 60 feet of cable length (the extender itself claims to be able to work up to 88 feet.
I have an HDMI 4x2 Matrix Switcher (http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=5312&seq=1&format=2)
So far, if I plug either the DVR or the HTPC directly into the HDMI extender, they will work fine. When I have the DVR and the HTPC plugged into the 4x2 HDMI switcher, I will get video sometimes, but never audio. If I have all the devices upstairs (taking the extender out of the equation) The switcher works just fine: video and audio.
Possible (unwanted) Solution: I can get another HDMI extender so I can port both devices' HDMI signals upstairs with 4 cat6 cables. BUT, then I won't be able to use the 2nd output feature that the HDMI switcher has. That is the reason I bought it in the first place.
Can anyone think of any reason why both the HDMI switcher and the HDMI extender would work alone, but not together? Am I just putting too many connections into the mix? Do I need some sort of HDMI power injector or signal booster (do they exist?)
Here is my setup:
