Problem with my Denon 1804 - Please Help!
Discussion in 'AV Receivers' started by davenportbuzz, Aug 27, 2004.
  1. davenportbuzz
    Jan 8, 2007
    33
    Just got a new Denon 1804 and made the major change over of cables from my previous Denon 3200. I was even able to do a test tone and hear all five speakers (and sub) sound off. After playing around with it for awhile though I've encountered a repeating problem that's driving me nuts now.
    When the reciever is in stereo mode - no problem. As soon as I switch to Dolby Digital or Dolby Pro Logic II (i.e. a surround sound format) the receiver shuts off completely and the "standy" light blinks. This strikes me as odd because at one point I was demo-ing "Hulk" to test the sound. It seemed fine then. And, as I mentioned, I was able to do a successful test tone to make sure the speakers were all hooked up. I'm sure the source is a surround sound one too on some satellite channels I tried.
    My first thought is that I crisscrossed my positive/negative rear speaker cables so I changed them and reconnected into the receiver (several combinations). It still shut off. I had previously hooked up the Zone 2 rear surround speaker (a third center rear) so I finally disconnected that to isloate the rear channel problem. Anyway, regardless of my troubleshotting on this, the receiver still shuts itself off as soon as a surround sound format is selected and begins to kick in.
    Can someone help me out with some advice on this? Everything else works fine (video cable inputs and standard 2-channel stereo audio). My front speakers, center, and sub are sounding fine, too.
    Much appreciated!
  2. Tyson Wetzel
    Tyson Wetzel Stunt Coordinator
    Jul 1, 2004
    112
    You need to check for a short in the speaker lead on the center and surrounds. A multi-meter would be handy.
  3. davenportbuzz
    Jan 8, 2007
    33
    It was the center channel. Duh! I can't believe I overlooked that for awhile. I assumed when it was surround sound related that it was the rears, but lo and behold, it was that I criss-crossed my center channel inputs. All is well now in 6.1 surround sound land! Thanks.
