Problem with H/K 325 receiver
Discussion in 'AV Receivers' started by brandon*b, Dec 21, 2003.
  1. brandon*b
    brandon*b Extra
    Aug 4, 2003
    17
    My H/K 325 AVR is about 3 months old. Yesterday I installed some outside speakers and used the multiroom function and everything worked fine. This morning, the receiver does NOTHING. The "standby" light is not even on. Does anyone know if there is a fuse that may have gone out or anything else it could be?
  2. David Ruggiero
    David Ruggiero Stunt Coordinator
    Mar 31, 2003
    132
    Well, have you checked that you didn't hit the power button or accidently unplug it? How about the outlet circuit breaker, possibly it tripped? Try unplugging the new speakers and see if that helps. Always check the easy stuff first.
  3. brandon*b
    brandon*b Extra
    Aug 4, 2003
    17
    Yes, my wife actually hit the power button (which I never use). Thanks for your help.
