Perry W
- Jul 28, 2001
I have a toshiba 3205 and I'm having problems with colored scan lines running horizontally across the screen. I have DVD connected to a Denon 3801, then to a Sony Wega (not xbr) with fairly inexpensive component cables.
Scan lines do not appear on all DVD's (non copy right protected). Also, if I use S-Video, lines do not appear. I have connected DVD directly to TV with component cable, and still have colored scan lines. I also have a playstation 2, and the lines appear with it using component cables to Reciever and directly to TV as well. No lines with playstation 2 using s-video either.
My question is, is this a matter of copy protection, or poor shielding in component cable, or both. Any suggestion as to what else may be causing this, and possible solutions.
Perry
Perry
