Hello everyone. I finally am hooked to the internet via Cable Internet. I Love the speed and the downloads but I'm having a problem with my connection disconnecting, much like Dial-up. The problem is that I'll be on a page and the "connect" light on my keyboard will go off signaling that I've been disconnected. I'll than try to go somewhere and as would be expected it doesn't go because I've been disconnected from the internet:frowning:.When this has happened I've tried to use the reset button on my modem and each time that hasn't worked, it seems the only way to get back online is to reboot my computer. I'm currently running a 4 year old computer(going @ 463MHZ) with around 64 MB of RAM (I know it's pathetic but I plan on getting a RAM upgrade soon.)My modem is a Linksys Etherfast which is plugged into my computer via the newly installed ethernet card which the installers had to put in. As of now I'm not running a firewall because all of the ones I've tried slow my computer down dramatically. What could be causing this disconnects? in all instances the TV cable was working fine. Since Saturday (when it was installed) I've had 5 disconnects.Could it be a problem with my modem? or is it a problem on the providers end? thanks.
