KevinHunt
- Aug 31, 2000
RS and TV and anyone else. I just got my 2 16-46s and Samson amp yesterday. I'm still waiting on another amp so I'm not doing the complete 5.1 calibration yet. I started by hooking up my left and right fronts and one 16-46. I did a quick calibration running the SVS just 3dB hot and listened to some music(STP) Right away with the first sub when bass notes would fade to quiet, I could hear a vibration noise from the listening position. I replayed the track and moved over to the sub putting my head down near the baseplate and listened again. I could hear a constant vibration/slight flapping noise. It doesn't sound like a bad driver because it is putting out good bass, but I can't figure out what the vibration is. If I slightly press one of my fingers on the driver when it is playing the vibration noise goes away. What else should I check for and is it possible that it's a problem with the driver? All things sound pretty good at the listening position until the music fades away or gets quiet and then I can hear it. I hooked up the second SVS and no vibration noise.
-Kevin
-Kevin
