Pro Logic II
Discussion in 'Archived Threads 2001-2004' started by BenjaminA, Dec 30, 2001.
  1. BenjaminA
    BenjaminA Extra
    Dec 27, 2001
    19
    I am looking at getting the Onkyo 696 and have a question about dolby pro logic II. I would like to use it to listen to music and watch movies. I see that is does not have something like circle surround mode that is on kenwoods. Would I be able to use pro logic II to play stereo music through all the speakers, so it would be like 5.1? Thanks
    Ben
  2. MartyV
    MartyV Auditioning
    Dec 28, 2001
    6
    I have a 797 and the PLII does a good job of creating a soundstage for music that is to my liking. The 797 also has a dsp stereo mode that all of the lefts front, side, and rear will play the left stereo and all of the rights front, side and rear will play the right stereo sound. I am not sure but would imagine that the 696 as the same dsp.
    Marty.
  3. Dan_Jones
    Dan_Jones Stunt Coordinator
    Dec 1, 2001
    120
    The 595 has all channel stereo...which I assume the 696 would. Is that what you're thinking of?
  4. Albert M
    Albert M Stunt Coordinator
    Jun 19, 2001
    222
    DPL2 is like SRS Circle Surround, the big difference is that DPL2 is a bit more tame with the surrounds. You will be happy with the 5.1 like effect of DPL2.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    CS 5.1 does a much better job than PL-II for music. Personally, I am not that impressed with PL-II. I have gotten away from listening to stereo music in any kind of DSP or matrixed mode as I do not feel it adds anything.
  6. DaveF
    DaveF Moderator
    Mar 4, 2001
    18,266
    1,646
    9,110
    One Loudoun, Ashburn, VA
    David Fischer
  7. Craig F
    Craig F Second Unit
    Jul 5, 2001
    276
    Craig
    When poeple first listen to DPL II, they want to really "notice" the surround speakers. With non-surround encoded material, this does not happen. DPL II creates a soundfield that blends beautifully. After listening to DPL II for a while, then switching back to plain stereo, the music sounded (to me) flat and empty in comparison.
    With surround encoded material, you will "notice" more activity in the surrounds. There isn't a lot of surround encoded CDs out there, but I have one which sounds great with DPL II.
  8. Michael Mohrmann
    Michael Mohrmann Screenwriter
    Dec 30, 2001
    1,394
    "With surround encoded material, you will "notice" more activity in the surrounds. There isn't a lot of surround encoded CDs out there, but I have one which sounds great with DPL II."
    How does DPL II sound with VHS tapes (2 channel, DPL, Dolby Surround)? How about with certain DVD movies (2 channel PCM, DD2.0)?
    Michael
  9. Craig F
    Craig F Second Unit
    Jul 5, 2001
    276
    Craig
    DPL II sounds vastly superior to old DPL on Dolby Surround encoded movies.
  10. David Cohn
    David Cohn Extra
    Jan 13, 2001
    19
    "The biggest weakness to the 696's implementation of DPLII is it doesn't provide any adjustment parameters. I think those are available in the 797 and up (and other brand receivers). But having never used them, I don't miss them."
    Even Dolby Pro Logic II-Music?
    My Denon 2802 has music parameters for width, panorama, and depth. The DPL II - Cinema only adjusts for cinema eq which I don't use.
    The DPL II - Music parameters are pretty handy. My center speaker is on the weak side so I have played with the width parameter.
  11. Craig F
    Craig F Second Unit
    Jul 5, 2001
    276
    Craig
    David,
    The Onkyo 494, 595, & 696, were among the very first receivers to offer DPL II, and do not have the music mode adjustments. The 797 & 898 came later and do offer them.
  12. DaveF
    DaveF Moderator
    Mar 4, 2001
    18,266
    1,646
    9,110
    David Fischer
    I'm not bothered by the lack of adjustable DPLII parameters on my 696; just pointing it out in case Benjamin is an adjustment freak [​IMG]
  13. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    When I first got my 595, I threw on the VHS of the original Star Wars trilogy... and was so impressed with the improvement in sound that I watched all three that day. Also, the 2-channel original DVD of Tombstone sounds INCREDIBLE in DPL-II. Even limited fidelity 2-channel tracks like Quigley Down Under sound notably better with DPL-II.
    If you really want to hear DPL-II shine for music, check out the CD HAUNTED by Poe. It's an absolute revelation (and a damn good album).
  14. Michael Mohrmann
    Dec 30, 2001
    1,394
    Thanks for the feedback about DPL II with VHS and 2 channel movies sources. I am in the process of replacing our Lexicon MC-1 with a different processor, but I wanted to be able to replace Logic 7 with something suitable for 2 channel sources. It sounds like DPL II is that "something". [​IMG]
    Michael
  15. Albert M
    Jun 19, 2001
    222
    SRS Circle Surround 2 will be here soon. Go to www.srslabs.com and look to the right and read the December 7th article.
  16. ling_w
    ling_w Second Unit
    Sep 3, 2001
    426
