Pro-Logic II; Is it decoded via digital inputs?
Discussion in 'Archived Threads 2001-2004' started by Robt_Moore, Jun 14, 2002.
  1. Robt_Moore
    Robt_Moore Stunt Coordinator
    Feb 27, 2002
    66
    10
    A la DTS or Dolby Digital?
    Is best decoding for LD players in DPL II via a digital output or the analog outputs? For example, Raiders of the Lost Ark (digital audio track).
    I would assume the issue is moot if the LD only has an analog audio track?
    Or, is this a function of the particular receiver? It seems to me that high end Yamahas used to boast that they decoded DPL in the digital realm.
    I am probably going to get a Yamaha HTR-5550 and plug in my Pioneer CLD-D502, if that makes any difference.
    Thanks.
    Bob.
  2. Roberto Carlo
    Roberto Carlo Second Unit
    Apr 14, 2002
    445
    It operates with both PCM digital or analog outputs. It also, as in the case of some DVDs and digital cable, works on the non 5.1 Dolby Digital signal being output.
    I don't have Raiders. On my OT Star Wars laserdiscs, I use the optical output on my player and it works just fine. I don't know if it's better than the analog. That's just the way I set my defaults. The results are very satisfying.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    DPL II also works on a 2.0 Dolby Digital signal too.
