Shawn Solar
- May 12, 2001
I have a Audiopro MOS 1200 pro-amp. Its for my sonosub. It puts out 1200rms into 4ohms bridged and is about 15yrs old. It is a mosfet design.
Anyway I can't seem to get any volume from it. I hook up the subout on my reciever to the amp then hook the sub(free air) to the amp. The sub is a blueprint 1503. I've tried putting a crossover between to boost the signal. I have an old sansui pre-amp that I put between and still get no volume. I hooked my mca anthem 2-channel up to the sub just to compare and it was a lot louder. It is only 200watts.
I seem to clip the signal if I run it too high(little indicator lights go to the top and the limiter light goes on) Also the sound gets distorted. I was wondering if they run on different signal types and if there is anthing I can use to match the signals/voltage. I had the amp checked out by a tech and it is in good working condition.(he even made an offer to buy it.)
