Printer Port (Code 29) - Help Needed
Discussion in 'Computers' started by DouglasRobert, Jun 16, 2006.
  1. DouglasRobert
    DouglasRobert Second Unit
    Sep 12, 2003
    269
    I recently got a used computer with Windows XP.
    I also have an Espon Color Stylus 640 Printer.
    I did the drivers for the printer, but when I try to print anything nothing happens.
    I gave the printer to a friend and the printer worked fine on his computer.
    When I looked up the Device Manager, the Printer Port is highlighted with a yellow circle.
    I clicked on the properties and found the following.
    This device is disabled because the firmware of the device did not give it the required resources. (Code 29)
    How do I make the printer port work?
  2. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    Just a guess: reboot the computer and go into BIOS Setup. Check that the port is enabled, and preferably set to ECP or EPP mode.
