Previouly Viewed Stickers
Discussion in 'Archived Threads 2001-2004' started by JackS, Sep 9, 2002.
  1. JackS
    JackS Supporting Actor
    Jan 17, 2002
    634
    Are there any tricks that anyone knows of for removing these stickers that are stuck on the front of the DVD case? I tried a hair dryer trying to loosen the glue a little with mixed results. Before trying the next one, I wanted to check here. Thanks, Jack
  2. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    use hair dryer to remove sticker, use goo-gone to remove sticker residue
  3. Jeff Kleist
    Dec 4, 1999
    11,267
    Hair Dryer is not a good idea on an actual disc BTW
  4. Chris M
    Chris M Second Unit
    Apr 15, 2000
    487
    I'll 2nd the Goo-gone suggestion... works awesome and smells good too.
    Chris.
  5. Gary Harris
    Gary Harris Stunt Coordinator
    Jun 8, 2000
    112
    Lighter fluid. Cheap & highly effective.
  6. Jeremy Allin
    Jeremy Allin Supporting Actor
    Oct 6, 2001
    895
    A little double-yuh-dee 40 works well, too! [​IMG]
  7. Joshua Moran
    Joshua Moran Supporting Actor
    Apr 11, 2000
    502
    LIghter fluid is best
  8. Patrick Larkin
    Patrick Larkin Screenwriter
    May 8, 2001
    1,759
    i bought a used disc with a center ring sticker. The problem is that the disc has paint all the way to the center.
    Has anyone removed one similar? I'm not sure what to use on the actual disc...
