GlennB
- Jan 19, 2002
I have a new Onkyo 600 receiver, a VCR, DVD player, cable box, & tape deck all mounted in an enclosed "entertainment center". The items are mounted top to bottom in order listed above in a 22 inch wide enclosure with about 8 in. air space above the receiver. The cabinet is pretty much enclosed with a solid glass door in front, solid side walls and the rear is solid except for a 1 1/4 in slot that runs top to bottom that is for running wires and cables. Just as I had feared, it gets pretty warm in there after the receiver has been on for a couple of hours.
I would like to remove the front door of the cabinet but my wife says NO! and I agree it wouldn't look good at all. I've thought of widening the rear slot and/or installing a small, quiet fan inside to stir the air up some.
Any suggestions? If a fan is in order, any suggestions on placement & make/model?
Thanks in advance for your suggestions.
Glenn Braden
San Diego
Glenn Braden
San Diego
