Dan Driscoll
- Aug 1, 2000
The unit is noticably bigger than my RP-91 (think Denon DVD-2900 size) and well constructed, but is light, only 11 pounds. The front panel looks good and has a nice, logical lay-out. The buttons are small and bullet shaped, but protrude out far enough that they are easy to operate. The well known Newcastle titanium finish works with both silver and black components.
Set-up and operation are logical and straight forward. Most experienced users will be able to configure the player without needing to read the manual, but read it anyway. Time alignment and bass management are applied to both DVD-Audio and SACD. Crossover settings range from 70-160 hertz, in 10 hertz steps and are applied globally to all speakers set as SMALL. Speaker distance and level settings are available individually for all 6 channels.
I have only watched a couple of movies (Serenity & The Great Raid), but video performance looks pretty good so far. I would rate the PQ as somewhat better than my Panny RP-91 with film sourced material. I have not watched any video sourced material yet. The make and model of the deinterlacer and MPEG decoder chips in the SD-860 are not known. I did receive a request to open my unit and check, but I declined. I have a fondness for warranties.
The main reason I got this player was for audio, especially SACD and DVD-A. DVD-A on the SD-860 is definitely better than on the RP-91. The SD-860 has better resolution, detail and frequency response than the RP-91, IMO. FYI, I only compared hi-rez stereo DVD-A (Alan Parsons' I, Robot on HDAD and The Corrs, In Blue), I didn't have MC set-up with the RP-91. FWIW, CD sound quality is acceptable, but my Carver SD/A-360 is noticably better.
I did not have an SACD player before this, so I can't comment on relative merits. However, stereo SACD doesn't seem to be a big improvement over well recorded CD albums. The difference between Elton John's re-mastered early CD's and the stereo SACDs is relatively minor, IMO. OTOH, multi-channel SACD is considerably different. Unfortunately, I can't compare it to CD, because the MC-SACD tracks on most of the disks I have are not the same mixes as the CD tracks. A lot of material and in some cases, time, has been added, at least on the early Elton John albums the were released on SACD last year. The MC-SACD mix of Razor Face (off Madman Across the Water) is almost 90 seconds longer than the stereo CD and SACD mixes. The same is true for a lot of the tracks on the DVD-A release of Fleetwood Mac's Rumours, so this is not exclusively an SACD issue.
Equipment used: Sherwood-Newcastle SD-860 universal player; Rotel RC-1070 preamp; Yamaha RX-V596 receiver/pre-pro; Carver SD/A-360 CDC; Sherbourn 5/1500A power amplifier, Vandersteen Model 2C mains, VCC-1 center, Paradigm ADP-370 surrounds, no sub, Pioneer SD-533HD5 RPTV, Outlaw Audio PCA and MAS Silver audio interconnects, Rhino Cables component video cables, Monster HTS-2500 Power Center.
