Mike Lazalier
- Jan 16, 2002
I had a dual ported 160 liter (5.75 ft^3) Tempest sub tuned to 19 Hz driven by a NHT SA-3 amplifier, but I felt that I needed a little more excursion (rather than a second Tempest - considering WAF) to faithfully reproduce the lowest frequencies with authority. So, I replaced the Tempest with a 15" Brahma driver from Adire Audio. The results are impressive. I tested the new setup from 20 Hz to 70 Hz (the primary frequency region I assign to the sub - 20 Hz was the lowest freq. on the disk; I assure you, it will plummit far below this) The test was done with a benchmark of 100 dB @ 60Hz. So, the measurements are nowhere near the limits of the sub. These are uncorrected values taken with the infamous Radio Shack meter. I realize that many of you frown upon simply replacing the driver in an existing enclosure, but I was more than a little bit curious. And, for me, it seems to have worked. I believe the setup will suffice:
For comparison, I included the old Tempest numbers (thus the need of a benchmark)
FREQ Brahma Tempest
20 94 87
21 94 87
22 94 88
23 94 88
24 94 89
25 94 89
26 9489
27 9690
28 9791
29 9892
30 9994
31 10096
32 10197
33 10298
34 10499
35 106100
36 107100
37 108100
38 109102
39 109102
40 108101
41 107101
42 106100
43 10499
44 10398
45 10298
46 10098
47 9998
48 9999
49 99100
50 100102
51 102102
52 103102
53 103101
54 102100
55 101100
56 101100
57 100100
58 100100
59 100100
60 100100
61 99100
62 9999
63 9998
64 9997
65 9595
66 9899
67 9698
68 9698
69 9597
70 9597
I realize the nasty hump at 39 Hz (I believe it to be a primary room mode or summation of a few given its neverending presence), but from what I have read, the BFD (my next HT purchase) can handle this with ease.
Mike
FREQ Brahma Tempest
20 94 87
21 94 87
22 94 88
23 94 88
24 94 89
25 94 89
26 9489
27 9690
28 9791
29 9892
30 9994
31 10096
32 10197
33 10298
34 10499
35 106100
36 107100
37 108100
38 109102
39 109102
40 108101
41 107101
42 106100
43 10499
44 10398
45 10298
46 10098
47 9998
48 9999
49 99100
50 100102
51 102102
52 103102
53 103101
54 102100
55 101100
56 101100
57 100100
58 100100
59 100100
60 100100
61 99100
62 9999
63 9998
64 9997
65 9595
66 9899
67 9698
68 9698
69 9597
70 9597
Mike
