Evan S
- Nov 21, 2001
For those of you who are using multi-zone preamps to control two separate systems from one pre/pro, can you explain to me how you have things situated? Do you have to run cables through walls to get to zone 2? Also, how do you remote control everything if the two zones are far apart? For instance, if you are using the pre/pro to power your main HT in the living room and also a separate bedroom system (zone 2), do you have any remote control capabilities from the bedroom or do you always have to go to the living room to change settings and such? Also, what do you do in the case of long cable runs between zones?
HT I kinda know...ergonomics in situations like this and I'm a total newbie.
Thanks.
Thanks.
