PreAmp without a decoder
Discussion in 'Archived Threads 2001-2004' started by TonyJK, Feb 6, 2003.
  1. TonyJK
    TonyJK Auditioning
    Feb 3, 2003
    4
    Does anyone know of a high-end PreAmp/Tuner WITHOUT a Dolby Digital decoder, that has BOTH inputs and outputs for Dolby Digital 5.1 signals????
    Thanks very much fir your help.
    TonyJK
  2. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    Do you mean a preamp/tuner with digial inputs/outputs?
    A unit that will simply pass the compressed DD signal does not exist to my knowledge.
    If you are not understanding what I am saying than you are infact looking for a preamp with DIGITAL in/outs.
    The problem that you are going to have is that "high end" pre-amps are usually totally analog. The pre/pros that do digital are going to do more than you want.
    Fortunatly, I think B&K currently makes one. And if I remember correctly there as a recent thread pertaining to this subject. Look around in the archives.
    good luck
    -rob
  3. NickSP
    NickSP Supporting Actor
    May 8, 2001
    569
    He might mean 5.1 Analog inputs.
  4. Kevin T
    Kevin T Screenwriter
    Jul 12, 2001
    1,402
    for the most part, all high-end pre-amps do not have tuners. one pre you might wanna consider is the mccormack map-1. it's a completely analog pre-amp with two 5.1 inputs as well as three stereo inputs. there is no tuner however. the map-1 retails for $2499 but you can purchase it for $2199 shipped from tsto.
    kevin t
