Preamp Output on Marantz not playing?
Discussion in 'AV Receivers' started by Jason.Soko, Jun 23, 2003.
  1. Jason.Soko
    Jason.Soko Stunt Coordinator
    May 30, 2003
    219
    I've always been running a Marantz SR6200 to drive all of my speakers.
    Recently I picked up a Moon I-5 integrated amp to drive my stereo configuration and I must say its absolutely stunning. So logically I decided to use my SR6200 as a pre/pro. When connecting the L & R preamp outputs to the I-5 I get no sound. The rest of the channels play out of the Marantz and the volume adjustment even works through the A4 "HT Bypass" input on the I-5. Any clue why I am getting no sound out of it?
    Yes, I checked all my cables and input selections on the Moon.
  2. Jason.Soko
    May 30, 2003
    219
    Any ideas guys?
  3. Donnie Eldridge
    Donnie Eldridge Supporting Actor
    Jan 3, 2001
    761
    Your speaker wires should be hooked up to the Moon, not the Marantz.
  4. Jason.Soko
    May 30, 2003
    219
    They are hooked up to the Moon , cmon now I'm not that dumb.
  5. VicQ
    VicQ Stunt Coordinator
    Aug 19, 2001
    87
    Does your Marantz have A & B front speakers, sometimes a receiver will unselect itself and you have to choose which one you want to use.
    -vic
  6. Jason.Soko
    May 30, 2003
    219
    Not that I am aware of Vic , I've been looking through menus like a madman. There has to be some setting that I am missing.
  7. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    There are no settings for the preamp outs, and there is no A/B switch.
    Have you tried running it in stereo with a stereo analog source to verify that the outputs are working?
    Disconnect all speakers and run just the mains?
    Are you SURE you have the correct 2 preamp outs?
  8. Jason.Soko
    May 30, 2003
    219
    I am positive I have the correct preamp outputs. Now I can get sound out of the tuner if I switch to that. No sound comes out if I use ANY digital inputs however.
  9. Donnie Eldridge
    Jan 3, 2001
    761
    Try calling tech support.
  10. Jason.Soko
    May 30, 2003
    219
    Ugh, Marantz tech support is death.
  11. Michael Mohrmann
    Michael Mohrmann Screenwriter
    Dec 30, 2001
    1,394
    Jason,
  12. LarrySkelly
    LarrySkelly Stunt Coordinator
    Jan 9, 2001
    129
    I have an SR-8000, was using it as a pre-amp for a Bryston 4B-ST.
    I even drove the main speakers off the SR-8000 and routed the left/right pre-out to an external crossover to drive a subwoofer, with no problem.
    So obviously you are attempting something that is common practice.
    I do know the SR-8000 has a setting for 2 vs. 6 channel output, although this should have no impact with you. Check it out.
    Try an analog output from your CD. Does it work?
    Connect your front speakers to the rear surround channels and try a Dolby Digital source? Do you get sound?
    Check the speaker settings? Not familar with the x200 series - are there unique settings for each particular configuration?
    Check the mute setting ... I'm getting desperate, as I'm sure you are when womething simple does not work ... #%@#$%#%#&(*#@. I went thru this all weekend trying to get a Classe SSP-50 to process a DTS source...
    Larry
