Preamp connections
Discussion in 'AV Receivers' started by Louisp, Jan 16, 2005.
  1. Louisp
    Louisp Stunt Coordinator
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    For example:
    GIVEN:
    HARMAN KARDON AVR 525 (7.1 AVR)
    TECHNICS SU-8080 POWER AMP
    Is it permissible to connect one or more of the AVR'S PREAMP OUTPUT's (i.e. SR) to an additional POWER AMP ....WHILE.... also connecting speakers to the AVR'S ....LIKE...SPEAKER OUTPUT'S (i.e. SR)?
  2. JohnSmith
    JohnSmith Supporting Actor
    Apr 8, 2003
    554
    If you mean using the HK for perhaps front three, whilst Technics for surrounds, or vice versa, and your HK has pre-outs for the channels you want, and you don't short out anything in the process, or have ground porlbems, then yes.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,187
    51
    9,110
    Katy, TX
    Wayne
    You’ll have to try it and see. Some receivers automatically disconnect the internal amps when the pre-outs are used.
    Wayne A. Pflughaupt
