Ken Woodrow
- Feb 12, 2001
The more I analyze my upgrade options, the more I realize that my needs for a pre/pro center around (1) sound qualityand (2) available bass management options.
My current configuration can be found in my sig, but basically consists of a HTPC (used as a DVD player), DSS with digital out, a Sony DB-930, and a LLano 3-channel amp driving my front channels. Speakers are Speakercity Aria 5 kits (front) and Madisound Vifa A/V kits. I'm using a 42" plasma connected to the PC and have no need for video switching.
My needs, in order of priority:
1. Sound quality, both in the digital processing and in the direct analog stage.
2. Direct analog pass through for at least 5.1 inputs.
3. Flexible bass management for digital inputs and the option for bass management on the analog inputs.
So, what pre/pros have the best combination of sound quality and bass management options? Esp. in terms of adjustable crossover points and slopes, individual channel gain and delay, etc.?
OR, is it better to handle bass management in the analog realm with an Outlaw ICBM? If so, why?
Oh yes -- my budget is up to $2000, which probably puts me in the used market.
Ken
Ken
