Pre/Pro with balanced outputs
Discussion in 'Archived Threads 2001-2004' started by Daniel_M, Oct 24, 2001.
  1. Daniel_M
    Daniel_M Stunt Coordinator
    Mar 15, 2001
    60
    Can anyone recommend a preamp/processor
    (Dolby 5.1/DTS etc. with 3 pin balanced
    outputs for under $5000.00.
  2. Brandon B
    Brandon B Second Unit
    Mar 23, 2001
    263
    Integra Research RDC-7 (MSRP $4000)
    Anthem AVM-20 (MSRP $3Ksomething)
    BB
  3. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Also, the Sunfire Cinema Grand mk II.
    The EAD Ovation and Encore-8 has balanced outputs for front left+right.
    The Cary Audio P-7 (I think that's the model #) has optional balanced I/O as well.
    I'm sure there are a few more that we're missing, but this should add nicely to the aforementioned list.
    John Kotches
    Contributing Writer
    Secrets of Home Theater and High Fidelity
  4. Frank Frandsen
    Frank Frandsen Stunt Coordinator
    Dec 15, 1998
    112
    Do balanced outputs improve sound much for wire runs less than a meter? I am getting a RDC-7 and will mate it to a Sherbourn 5/1500 amp. I can get the older model Sherbourn for $500 less than the new model 5/1500a. The main difference between the two appears to be the balanced outputs on the new model..Should I save the cash on the older one or go for the balanced?....that is the question.
    Frank
  5. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
  6. Dela Rosa
    Dela Rosa Auditioning
    Oct 22, 2001
    9
    Though it's getting left behind in the "new" format race, I'll need to plug the Aragon SoundStage. I love it, but a used one will be WELL below your $5k target (around $2k to $2.5k). Also, no six or seven channels, just DD and DTS (with balanced outs). And no DPLII [​IMG]
    Upgrades are reportedly on the way, but honestly, I just switched to this PrePro just to get up into the DTS realm (ducks to avoid flying objects). [​IMG]
    Christian
  7. John Kotches
    Mar 14, 2000
    2,635
    I knew I was missing one or two!
    Yeah, I can't wait for an updated version of the Soundstage with all the latest bells and whistles.
    John Kotches
    Contributing Writer
  8. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    The Integra Research RDC-7 with the new DTS-ES Discrete 6.1 and ProLogic II upgrades is a hard act to follow in the $4,000 and under category. It even gives some slightly more expensive processors a run for the money too.
    Some reviews I've read have stated using its balanced outputs into a balanced amplifier did create a better sound quality and a quieter noise floor (into a B.A.T. amplifier and a Theta Dreadnaught). Not by a huge margin, but it was noticable.
    I'm sure it also depends how "balanced" the balanced amplifier really is. Some with XLR inputs do not have a 100% balanced electronic topography.
    Dan
    Stop HDCP and 5C-- Your rights are at risk!
  9. BobL
    BobL Agent
    Sep 6, 2001
    32
    Bryston SP-1
