Pre/pro output Volts to Amps input sensitivity
Discussion in 'Archived Threads 2001-2004' started by Kevin. W, Mar 22, 2002.
  1. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    I was wondering if someone can explain the relationship of a Pre/pro's out put Voltage to the Amps input sensitivity. I remember reading some where that if the Pre/pro doesn't put out the proper Voltage then the Amp won't reach its max output??
    Kevin
  2. chung
    chung Stunt Coordinator
    Feb 23, 2002
    234
  3. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    If the pre-pro's maximum output is lower than the amp's sensitivity, then yes, you won't get "full output", meaning, you won't be able to push the amp all the way to clipping. With modern gear, this is pretty unlikely, because most pre-pros have 2V max output, and most amps have .5V - 1V input sensitivity. Also, this has nothing to do with whether the combination plays loud enough, this is about whether you can push the amp to its maximum.
