Pre/Pro/Amp for $3000 - Suggestions
Discussion in 'Archived Threads 2001-2004' started by Mike OConnell, Jul 3, 2002.
  1. Mike OConnell
    Mike OConnell Second Unit
    Jun 14, 1999
    489
    110
    Overland Park KS
    Mike
    This is a totally honest question. I have a Denon 5800 that I can upgrade for a total cost of $850. I can probably sell the unit for $1800.
    If there a pre/pro/amp that can power seven channels that I can buy for a sum total of around $3000 - including all 7 interconnects between the units, shipping, and/or taxes - that would do as good a job as an upgraded Denon 5800?
    Mike
  2. itai
    itai Stunt Coordinator
    Jan 23, 2002
    221
  3. Phil A
    Phil A Producer
    Oct 1, 2000
    3,205
    51
    4,110
    Central FL
    Phil
    You may wish to look at the new Rotel receiver. It has 5 amps but they are assignable so that you can get a bigger amp for the front channels and use the built in ones for rears in 7.1. With an outboard Rotel 2x130W channel amp it will be about $2k list. Not haveing to drive the front speakers will make the internal amps free for less demanding channels and perform much better. If you want separates, the Rotel pre/pro is about $1,500, leaving a decent amt. for amps.
