Kevin_R_H
- Jan 3, 2002
Larry,
My contrarian stance (as I've posted numerous times here) is to keep your receiver, and don't buy a new pre/pro.
My advice is to buy a stereo preamp. If your system is 50% music (I assume 2-channel), don't allow some evil HT pre/pro anywhere near your 2-channel signal path.
Simply patch all 2-channel inputs into this stereo preamp, allowing you to bypass your HT receiver completely.
When watching DVDs, the signal for the Mains can be patched (via PreOuts) from the receiver directly into this stereo preamp, and selected as a source. This way, this stereo preamp and Bryston power block are integrated into HT as well as 2-channel.
This way, your receiver is nowhere near your 2-channel enjoyment, and it's sole purpose for DVDs (as a power amp) is to power the Center and Rears. For DVDs, it will still serve as a pre/pro. You can find other posts I've made relative to this "challenge".
The bottom line is that one would expect to be able to find a $2,000 stereo preamp that will outperform a $2,000 HT pre/pro (although I'm sure there are multiple exceptions to this assumption). After all, a HT pre/pro has more tasks to handle, and these extra tasks have an associated cost.
If stereo music is half of your system's usage, NEVER allow HT to compromise it!
Kevin
Kevin
