Pre-out jumpers/loop? Need quick help (1 Viewer)
KyleGS
I've read a few times that people were disappointed in their "stock" jumpers when using a pre-out loop. I just purchased a new stereo (H/K) reciever. Look at the picture below.
Should I consider replacing my jumpers? Could someone tell me where to find high quality jumpers? Thanks
Jazzy title
Saurav
If it ain't broke, tweak it till it is :)
Some people make jumpers for such applications, I don't remember the manufacturers any more. Or you can build your own very short interconnects if you have the skills/tools/time.
Bruce Cadotte
Tara Labs makes some that i use with mt Integra 9.1,they do help make things sound more detailed then the "stock jumpers"(i switched between the 2)
i believe they are about $30.00 for a set of 2.
