Pre-Amp ????
Discussion in 'AV Receivers' started by Mark Nguyen, Aug 16, 2003.
  1. Mark Nguyen
    Mark Nguyen Stunt Coordinator
    Sep 26, 2002
    174
    Hi guys,
    Any suggestion on a pre-amp? Looking to go separate, already have Rotel power amps and just debating whether to get a receiver like Denon 3803/Kardon avr-7000 OR get a decent pre-amp.
    Is there any pre-amp out there that's better, processor-wise, than the two receivers above in the same price range?
    Mark
  2. Vishnu Th
    Vishnu Th Auditioning
    Nov 14, 2002
    11
    Outlaw 950 is in your price range.
  3. Tom Grooms
    Tom Grooms Second Unit
    Jul 17, 2000
    273
    HT or 2 channel?
  4. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    I'd probably go with the 3803 (notice the disclaimer in there though).
  5. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
    You mean preprocessor. I like the cheaper receiver + stereo preamp route. YMMV.
  6. Mark Nguyen
    Sep 26, 2002
    174
    I do HT/music 50/50. Want a piece with DD/DTS, etc. I am leaning towards 3803 ... I've read many good things about it, I guess I will just have the extra amps. [​IMG]
    How does the Outlaw 950 compare to it?
    Mark
  7. Craig_Kg
    Feb 25, 2002
    768
    When you say music, do you mean surround music (and does this mean DD/dts DVDs or DVD-A/SACD) or stereo?
  8. Mark Nguyen
    Sep 26, 2002
    174
    Craig,
    No, just 2 channels music...though I am getting used to Denon Direct mode for 5 channels music.
    DD/DTS, etc is for HT. (movie)
    I would like to eventually go into DVD-A/SACD.
    Mark
  9. Craig_Kg
    Feb 25, 2002
    768
    If 2ch music is the most critical listening, then get a cheaper receiver like a Denon 2802 and put the spare change into a stereo preamp for your pure stereo sources.
