Dave Miller
- May 9, 1999
Hope you guys can help. Just moved into a new house and put two Elan outdoor speakers out on my back porch. Currently they are connected to the Denon 3300 AVR in my living room as the "B" set of surrounds. It does work as I only want them to come on when I'm listening to music in 5 channel stereo, but I'm not happy with the sound level on those speakers. Obviously having them connected as the "B" set or surrounds isn't cutting it. I'm assuming I need an amp.
Do I need a pre-amp or an amp and what's the difference. What brand should I go with?
I want something with a thin profile, simple to use and cheap. I only need to drive these two speakers and I only want to spend about $150 -$200. Upgrading to a new receiver is not an option right now, but will be in a few years, hence why I don't want to spend a lot. Is this possible or am I out of my mind?
Will I just run a set of RCA's from the multi-out on the Denon to the amp and then connect the two sets of speaker wire?
Thanks in advance.
Peace,
DM
Thanks in advance.
Peace,
DM
