Trevor Schell
- Jan 6, 1999
Hi!,
I was just measuring up the size of screen I would go with.
The two chioces I had are as follows.
92"Diagnol (45"x80")
106" Diagnol (52"x92")
Of course my first choice is the 106". This will actually completely cover my Entertainment unit which is 94" wide,2 inches wider than the screen size width. The screen would be mounted directly from the ceiling in front of the Entertainment unit.
However,,would this be too big of a screen to veiw with the seating area at 16 feet away from the screen.?
Would the 92" be more practical?
Is there a certain height limit from the ground to the bottom of the screen that should be allowed?
I would also need to go with a THX acoustically treated screen which is made of the Micro-perf material since my center channel would need to be behind the screen.
Trevor..
Link Removed Sonically Enhanced
*Outdated pictures due to recent upgrades!
Trevor..
