Nat Ward
- May 23, 2003
Hello, this will be my first try at a DIY project, and it would help if a few of you who have done this before would double check my design. I plan on using the Adire Audio Tumult, 2 Stryke Audio 18" passive radiators and the Kiega 52100 (1000W) plate amp. Using WinISD Pro, it appears that a 113L enclosure with 1600g PRs has a nice roll-off and goes 3dB down at 24Hz. But searching through other threads, other people use larger enclosures (5-5.5ft^3) and the heavier 2500g PRs. When I plotted those against my design their curve seemed flatter, and only had an advantage from 15Hz down. Am I missing something? Use will be 60% music, 40% movies, and would be in a room 25ft x 15ft. And just to make sure I didn't make a stupid mistake, under the "PR" tab when the program asks for "added mass to the cone" the value would be 1600g for the 1600g Stryke PR, correct? It doesn't know the mass from the other parameters (Vas, Qms, etc) and me putting 1600g in the block really makes it a 3200g PR? Thanks for any help.
Nat Ward
Nat Ward
