Not alot. I blew up and rebuilt my entire set up. I am now running 2 Shivas in an IB. They bottom out fairly easily listening to music. However, I have not had them do it during movies. I have not measured power nor the in room FR. Suffice it to say, they have reached 110 dB in my 3200 ft^3 basement room. I am using an old Pioneer Pro Logic receiver with 125 W per coil or 500 W total. Mind you this is the smoothest bass (by ear) that I have had. Just when you think you have found sonic utopia..... I have also had these Shivas in sealed, ported and TL arrangements.
Thanks for the reply, I am running a 75l sealed DPL12 with my nad 3150 (~65 watts/coil) I find that this setup has no problem producing enough spl for me and I might add that it also sound great. But, I think I caught the DIY bug, I want to try my hand at another project. I have the perfect location to experiment with an IB and thought that if I could cut the cost if the nad could produce enough power. My entertainment room is on the main level and I have a ~ 12”x15” heating duct beside my left main. I thought that I could pull duct and use this access for experimenting.
I use the Parts Express 250 watt plate amp to power two IB Dayton 15" subs in an IB alignment. I reached 110db at 16hz. Flat response from 16hz - 125hz. I didn't try test tones below 16hz, hmmm, there's a project for the weekend.
15", ok I'll watch for a sale. I guess i was thinking 12 because of the location that I want to put the IB. it's 12"x15" with the 15" side hard against the wall. would it cause a problem if the mouth/opening was slightly maller than the sub box.
$119 sounds good, but I am concerned with shipping cost, exchange and duty. I seam to be limited in what I can find here in Canada. I may have to brake down, but when your looking at 45 -60% increase. I have heard of the 15" I.B. Dayton, how do they work compaired to the Tempest. I can get one for $202.00 can. I thought that I would watch them for a sale. the 119 Dayton would be 160 can + shipping + duty.
