Powered woofer question
Discussion in 'Speakers & Subwoofers' started by Keith_R, Feb 9, 2004.
  1. Keith_R
    Keith_R Screenwriter
    Jun 16, 2001
    1,172
    110
    FL
    Kyle
    Hey all, a pretty basic and simple question, but is it safe to leave your powered subwoofer on all the time even when not in use? thanks.
  2. Mike_Skeway
    Mike_Skeway Second Unit
    Jan 13, 2004
    265
    Yup, no problem.
    FWIW, I leave almost all of my gear on. Except for the TV, XBOX, VCR (never use it any more), and DVD (auto shutoff).
  3. Dustin Harrison
    Dustin Harrison Stunt Coordinator
    Jan 14, 2004
    96
    It seems that most these days come with an "auto on" circuit. For those that do not, I would say it's safe to leave it on. I would turn it off if you're not going to be using it for awhile, like if you were to take a vacation.
  4. Chad A
    Chad A Stunt Coordinator
    Oct 21, 2002
    113
    Yes, you can leave it on but if it has a auto-on feature use it.
    When it reads a signal coming from your reciever it will automatically come on and shut off when there is no signal for 20-30 minutes.
  5. Chad A
    Oct 21, 2002
    113
    Now that's what I call service, three answers in two minutes.[​IMG]
  6. Mike_Skeway
    Jan 13, 2004
    265
    [​IMG]
  7. John S
    John S Producer
    Nov 4, 2003
    5,460
    I leave mine on, becasue I have a line level cable running a mile from my AVR to it, and the auto-on feature is iffy at best with the ultra long cable.
  8. Keith_R
    Jun 16, 2001
    1,172
    110
    FL
    Kyle
    I figured as much. Thanks.[​IMG]
  9. Mitch G
    Mitch G Agent
    Feb 3, 2004
    48
    FWIW, I just asked this same question to Paradigm about the PDR-8 which does not have an auto shut-off. They said it should be turned off when not in use. [​IMG]
    Although, I can't imagine what would be wrong with leaving the sub on all the time, being the paranoid that I am, I decided to get a Smart Strip power strip so that I can have the sub turn on and off in conjunction with the receiver.
    Mitch
  10. Mike_Skeway
    Jan 13, 2004
    265
    I wouldn’t sweat it. Either way, on or off you will be fine.
