Jedd
- Feb 5, 2002
I was told couple times by different people that it's bad idea to have powered woofer in the tower. It's bad for music and even worse for HT. Can you explain why?
I have powered towers and a sub..and love them
Have them both is the best, but expensive thou.
Been more specific I'm thinking about AR5 from acoustic research or probably AR9 and separate sub. (maybe the same carver sunfire) But separate will cost me two or tree hundreds more...
If it was written in stereo, why it shouldnt be played in the same way?
First, low bass frequencies are different in that they are highly affected by the room. Second, in most situations "stereo bass" is a misnomer (sp). There may be bass in both speakers but it is not stereo. Just like if you have a mono switch on your amp. Music will come from both speakers but not stereo. As far as, "is two subs better than one?"
That is a somewhat hotly debated subject for this and other forums. There are possible advantages but it takes a lot of tweaking and tuning to get the most potential from multisub setups. For a lot of people you can do as well with less trouble with one sub or more accurately, subs in one location. ie.. some people put two SVSs or Adires or whatever in the same corner of the room.
This is where people may be a little off IMHO...a powered tower is not simply another sub thrown into the mix...rather, it is a near full range loudspeaker where the blending between highs/mids/lows has already been controlled by the manufacturer. I have powered towers with built-in 15 inch woofers...and they haven't been super difficult to place. The most important thing is that they have some room to breathe on the outsides (where the side-firing woofers fire)...but other than that, they shouldn't be very problematic I think.
Most bass tracks on a recording are mono. A good way to test this is to use a good set of earphones that can play good bass and listen carefully. You should most likely hear the bass right in the middle(mono). This way you can get both woofers to help each other out with the bass, being as low frequencies are the most difficult to reproduce. Making the bass mono makes it easier for a system to produce louder bass without overstressing the Amp or woofers.
Try it out with some headphones and see if you can hear the stereo imaging with low frequencies.
So I still didnt figure it out: what will be the better deal
1) buy powered towers for $900
2) buy the same towers in unpowered mode for $600 and add a sub for $300
If you have no intention of upgrading, and if you are using this setup mainly for movies, then option 2 would probably be the better choice. Why? Well, I feel that it is highly beneficial to add a quality external sub to virtually ANY loudspeaker, particularly for movies. If you have some intentions of upgrading in the future, and assuming that you will be able to give the powered towers some room to breathe, and particularly if you listen to a lot of music, I think you would do well to consider option 1, and add an external sub down the road. Value is a relative thing...if you get the feeling that powered towers + external sub will lead to a more satisfying setup in the long run than nonpowered towers + external sub, then I would say that the additional expense certainly may be worth it. I can tell you that near full range capability from your main channel loudspeakers should be considered to be highly desireable IMHO, particularly if these speakers work well in your room.
I just wonder why people say (I heard from an audio dealer) that it's a bad design, all company quit it, there is no real good speakers with powered subs in, companies who make good speakers have no idea how to make subs and if they do they do it separately etc. etc.
i don't know about that - no less of a speaker company than duynaudio is releasing their new Confidence C7 speaker soon, which is a powered tower.
check it out here
anyway, i have to agree with bob - powered towers (particularly those by definitive technology ) are a fantastic solution in my experience. my own def-tech towers offer an absolutely superb soundstage and spectacular imaging. and the bass goes all the way down past 20hz into the pictures-falling-off-the-walls nether-regions of bass. and it's fast, clean, tight, and wonderfully musical to boot.
even though, i still plan on picking up a subwoofer or two as well.
'cos there's never enough bass....
my suspicion is that people who quote loudspeaker design theory as their reasons for rejecting powered towers either haven't heard them, or haven't heard them set-up well.
