Powered Tower Owners...
Discussion in 'Speakers' started by John Robert, Sep 9, 2003.
  1. John Robert
    John Robert Stunt Coordinator
    Sep 6, 2003
    193
    Have recently purchased on closeout a pair of Infinity 4.1ts for $2K from Audio Advisor. I am experimenting with different setups and wonder if you:
    1) Just split LFE signal and run to sub input on mains.
    or
    2) Run speakers as large with additional sub. (I already had Polk 650)
    or
    3) Use some kind of sub "plus" mode on your receiver or pre/pro
    Maybe there is some other choice I'm missing. Thanks for your help...
  2. JamesG
    JamesG Extra
    Feb 14, 2001
    17
    I have Polk RT3000s, a powered tower that goes down deeper than my separate sub (coincidentally, a Polk 650). I use a different approach than the 3 you outlined.
    On my pre/pro, I set sub to "off" and fronts to "large". This sends all LFE to the fronts. I run two sets of speaker wire from the "front" outputs of my amp - one set to my left and right front speaker, and one to the sub. The sub is set to only play signals < 40 hz.
    This approach sounded better to me than splitting the LFE output of my Pre/Pro to my 3 subs (2 towers and 1 freestanding).
    Hope this helps.
  3. DarrenAlan
    DarrenAlan Stunt Coordinator
    Jul 23, 2002
    172
    On my A/V receiver, I have three choices:
    1) Mains as small, LFE to sub
    2) Mains as large, LFE to mains (routes LFE from other speakers set as "small" to mains rather than sub)
    3) Mains are large, LFE to "both"
    If you run "both," you can merely set the sub to fill in the frequencies where your mains roll off. If that's 35 Hz, say, a sub Xover setting @ 40 Hz (depending on the crossover slope) might work quite well.
  4. terence
    terence Supporting Actor
    Nov 8, 2002
    985
    I run my mains in (large) full range and then phase them in with my sub. I must say it sounds great and was the best for my needs.
  5. RISUG
    RISUG Stunt Coordinator
    May 3, 2003
    179
    I have mains set to "Large" and subwoofer set to "None".
    The lfe is routed to the subs in each tower via the speaker
    level connection.
    Daddy like.[​IMG] [​IMG]
  6. RISUG
    May 3, 2003
    179
    Greetings Terence, my fellow AR breathren. [​IMG]
    [secret handshake]
  7. John Doran
    John Doran Screenwriter
    Jan 24, 2002
    1,329
    6
    i have my mains set to "small", and have my sub doing all the rest of the work (everything 80hz and below).
    i found that the subs in my towers (def tech bp 2000tl's) would audibly distort when i ran the towers at "large" and tried to listen at anything approaching reference...
  8. terence
    Nov 8, 2002
    985
    Greetings as well Reese, my fellow AR breathren.[​IMG]
    [secret handshake]
  9. Holger
    Holger Stunt Coordinator
    May 29, 2002
    87
    I have a pair of Def Techs BP2000Tl and they are set to *large*. They do handle the .1(LFE) signal as well, I connected them via a y-adapter to the sub out of my pre-amp.
    Bass response is wonderful dynamic and always crystal clear. They never sound boomy or produce audible distortion. Even at the highest spl's at reference level (which can easily be 105+ db's) they always sound extreme natural und clean.
    regards, Holger
  10. Greg Bright
    Greg Bright Second Unit
    Feb 24, 2000
    265
    2
    Gregory Bright
    I have a pair of Infinity IL60s that I have set to small. I run outputs to their powered sections from the sub which has a steep high-pass crossover set to 50Hz. So the sub just handles content below 50 and the towers everything above. I tried several other approaches before settling on this one because it eliminated the very low frequencies coming from three different locations and made everything much easier to calibrate.
    Greg
  11. Kirk Mango
    Kirk Mango Stunt Coordinator
    Jul 8, 2002
    88
    I own Mirage OM5's for mains and run them on large. My sub setting is on yes and all LFE is sent to sub. I also have a line level connection to my mains and the sub picks up anything the mains cannot handle. Crossover on line level is set to around 25hz. All other speakers are set to small and the sub handles all bass around 80hz and below for them.
    KM
