PowerDVD problem (won't play)
Discussion in 'Computers' started by Jeff Jacobson, Oct 4, 2003.
  1. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
    I am having a problem with PowerDVD 3.0. I can't get it to play any DVDs. When I try to play a DVD, the screen just goes black, then keeps clicking repeatedly, as if it trying to change the monitor resolution settings over and over.
    I can play DVDs just fine with other software such as ATI Multimedia Center 7.6 and Windows Media Player.
    PowerDVD used to work for me. I'm not sure when PowerDVD stopped working, as I only use PowerDVD when I want to do screen captures from DVDs.
    Can anyone help me get PowerDVD working? (I haven't been able to find any info on this problem when I searched.)
    Thanks.
  2. BenSC
    BenSC Stunt Coordinator
    Jun 19, 2003
    190
    Very odd.... Try making sure the Play Full Screen option is unchecked and see if it will play in a window. Perhaps its got a conflict with your current resolution.
    If screencaps are all you want, open the DVD in Media Player Classic or any old program, then do an Alt-PrintScreen (captures to clipboard) and then paste it into your image editing program and crop out the screen.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Try going into the settings and TURN OFF hardware acceleration. Let us know what finally fixes it.
  4. Randy_T
    Randy_T Stunt Coordinator
    Dec 18, 2001
    95
    What OS are you using? If it's WinXP, you'll need to patch your 3.0 software. You could also uninstall and reinstall Power DVD, and see if that clears up the problem.
    RGT
  5. Jeff Jacobson
    Dec 24, 2001
    2,116
  6. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Did you install any other DVD programs or video codecs lately?
    -Dave
  7. Jeff Jacobson
    Dec 24, 2001
    2,116
