Ryan Patterson
- Nov 11, 1999
I'm experiencing a weird problem with PowerDVD that I've seen in all versions from 2.55 all the way up to XP 4.0. It seems that PowerDVD will drop frames in movies at exactly the same spot. The one major example I always use in testing is Star Wars: Episode I. Near the beginning, when Obi-Wan and Qui-Gon are flying towards the Trade Federation ship, Qui-Gon calls to the Captain. The captain leans over and says, "Yes, sir?" As she leans over, the movement jumps a frame or two. When I play this same sequence in WinDVD, the motion is smooth with no jump. When I disable my SB Live 5.1 card and run the movie in PowerDVD with no sound, it runs smooth with no jumps. This suggests that the sound card may be the problem, but Cyberlink indicates that PowerDVD is compatible with SB Live 5.1, and I have the latest drivers (which doesn't say much as Creative has never released any new official updates to their CD drivers). The card is on IRQ 9 and is only sharing with "ACPI IRQ Holder for PCI IRQ Steering". DMA is enabled for all CD/DVD/HD drives and I have closed all other programs while running PowerDVD. Does anybody else experience this problem? Full system specs are below.
Thanks a bunch!
Ryan
AMD 1 Ghz / 266 bus
Abit KT7A Motherboard w/ 4.42 VIA 4in1 drivers
480 MB PC-133 SD-RAM
Windows ME
Asus V7100 GeForce2 MX
Creative SB Live! 5.1 OEM
3Com 3C900-TPO NIC
Creative Dxr2 DVD Decoder
Maxtor 40 GB HDD, DMA enabled
Daytek 16/40 DVD-Rom, DMA enabled
Plextor 16/10/40 CDRW, DMA enabled
Thanks a bunch!
Ryan
AMD 1 Ghz / 266 bus
Windows ME
3Com 3C900-TPO NIC
