Power cord extensions
Discussion in 'Archived Threads 2001-2004' started by David Judah, Nov 15, 2002.
  1. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    I'm moving some equipment around and my power amp's cord(Sunfire Cinema Grand) is not long enough to reach the outlet anymore.
    If I get a sturdy power cord extender, do you think there will be any appreciable loss?
    DJ
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    nope.
  3. David Judah
    Feb 11, 1999
    1,479
    That's good enough for me.[​IMG]
    DJ
  4. Brian OK
    Brian OK Supporting Actor
    Aug 29, 2000
    550
    David,
    "nope" ?
    I would seek another opinion, perhaps another user of the Sunfire CG. Perhaps you could ask an actual user who has encountered any appreciable loss in performance with adding another supply cord connection.
    I am amazed that you would simply accept four letters as anything other than 4 letters.
    Hey, it's your system..................
    good luck
  5. David Judah
    Feb 11, 1999
    1,479
    Well, I was going to try it anyways(small investment of time and money), but I thought I would run it by my HTF brethren first.
    My impression would be that it wouldn't make a difference, but I've been suprised before many times with this hobby.
    We'll see...
    DJ
  6. Brian OK
    Aug 29, 2000
    550
    David,
    My concern would be a loss in transient response, as that power hungry amp could possibly be short-changed when bass hungry or simply dynamic passages occur in movies and music.
    Keep an ear out for sloppy bass notes and loss of HF
    detail. The amp may lose some control over your speakers drivers and a general fuzziness may be evident.
    Try it, see what happens. My .02
    Good Luck,
    BOK
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    the amp does have capacitors doesn't it?
  8. David Judah
    Feb 11, 1999
    1,479
    I bought a Monster cable extension that is at least as thick as the Sunfire's cord and I'll be damned if I can hear a difference.
    Of course, I didn't perform a DBT and write a paper for peer review, but I feel pretty confident that my ears didn't steer me wrong in this case(I've been reading the $10k golden ears amp challenge in the receivers/seperates/amp forum[​IMG]).
    DJ
  9. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    I had a terrible hum which generated, I felt, from my amp, which was hooked up to a Monster Power line conditioner. I tried a whole bunch of stuff, then last weekend, bought a very high capacity power cord to try out a different outlet. Not only did I notice no dropoff in sound, but the hum is now all but gone. I'm no electrician, so I don't know why, but it worked for me.
  10. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    An issue with the former outlet suggests itself as a possibility. Perhaps now you're on a different circuit. Or perhaps your former cord was defective in some way. Either way, good to have the hum gone [​IMG]
  11. I have a crown K2 which can put out up to 2500watts RMS into 4ohms...of course I have it wired up to "only" 800wattsRMS/channel at 4ohms/channel.
    I DO actually use most of the amp power on transients. I have driven it into clipping on a few occasions.
    The amp comes with only a ~3ft cord. I added another 4ft (over 100% increase in original length) using 12awg cable. No audible change here [​IMG]
  12. Brian OK
    Aug 29, 2000
    550
    .....except when it clips........
  13. clipping is not a power cord issue
  14. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
