POWER CONDITIONER (1 Viewer)
Lew Crippen
It depends on what you are trying to do.
Personally I think that an inexpensive UPS/surge protector/voltage regulator (around $150) will meet most requirements.
APC is a company that usually makes sound products at a reasonable price—but I have no personal experience with that particular product. Looking at the specs, it is targeted towards higher-end gear (which you might or might not own).
FROGMAN
Michael Lugar
I have the following:
Panasonic 58PZ800 Plasma
Denon 3808
PS3
2 Sony CD/DVD Carosel
Dish HD Receiver
2 Defenitive Tech 2002 towers w/ powered 12" subwoofers
Testing Rel T2 powered 10" subwoofer
FROGMAN
Michael Lugar
I assume with no responces that a power conditioner is not used very much, everyone must plug into the wall!
Lew Crippen
There is a bit of a difference between using a Power Conditioner or less expensive surge protectors or UPSes and plugging directly into the wall.
I own no power conditioners, but I do have all of my electronics connected to UPS/voltage regulator/surge protector devices (three different ones).
Kevin Stewart
Texas
Kevin Stewart
I agree with Lew. I no longer use Power Conditioners, but instead use UPS's on all my equipment.
I'm currently using this one in my home theater (Belkin 1500VA):
And this one in the living room (power sentry 1000VA):
wilsonvn
