Power Amp Question... How to drive TWO sub woofers?
Discussion in 'Archived Threads 2001-2004' started by Bill Johnston, Jan 17, 2002.
  1. Bill Johnston
    Bill Johnston Stunt Coordinator
    Nov 20, 2001
    77
    I am selling a Power Amp (specs below)... The guy that is interested in the Amp has asked me...
    "Can this amp drive two subwoofers????
    I want to have crossfiring subs.
    I have the matching KR-X1000 receiver."
    I'm assuming that he would take the "pre out" for the sub from receiver... and then he would plug it into the "mono/left" channel... and then hook up his sub's on the right and left speaker connectors...
    I've never used these power amps that I am selling so I was hopping you guys might be able to help me anwer this...
    Thanks!!!
    Bill
    STEREO MODE
    130 watts per channel minimum RMS, both channels driven @ 8 Ohms, from 20 Hz to 20,000 Hz with no more than 0.01% total harmonic distortion (FTC).
    MONO MODE
    270 watts minimum RMS, @ 8 Ohms, from 20 Hz to 20,000 Hz with no more than 0.03% total harmonic distortion (FTC).
  2. Brian Fellmeth
    Jul 30, 2000
    789
    Are the subs powered ? The hookup options are different for powered vs passive subs.
  3. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    If it's a regular stereo amp, I'm thinking that he'll need to have a Y-connection at the inputs so that the L & R see the same signal. Then, hook up two subs as you describe.
