POTA DTS sound drop out
Discussion in 'Archived Threads 2001-2004' started by AaronG, Nov 22, 2001.
  1. AaronG
    AaronG Stunt Coordinator
    May 15, 2001
    185
    Hi guys! Has anyone else been getting audio drop outs while using the dts track on Planet of the Apes (2001)?
    It has happened in a few spots. The sound drops out for a split second. When I rewind it, it cut out in the same spot a couple of times and then plays normally. Is this a bad disk?
    Aaron
  2. MichaelG
    MichaelG Second Unit
    Jul 10, 2000
    322
    I also noticed a few audio dropouts from the DTS track of Planet of the apes last night. I watched it at my friends and he has a Sony DVP-S360 DVD player. I can remember it happening about three times. Anyone else?
  3. Scott Simonian
    Scott Simonian Screenwriter
    Jun 20, 2001
    1,281
    No, I did not notice a single dropout. Where in the film are these dropouts happening? Ill take a peek if I know the spots.
  4. John E F
    John E F Stunt Coordinator
    Nov 18, 2000
    74
    I experienced the DTS dropouts for about the first fifteen minutes with my Toshiba 4700. I tried it on a Toshiba 3750 and the Sony NS700, with DTS dropouts on all three. I switched over to Dolby Digital with no more problems. The dvd was a rental (thankfully), but I rented it new on Tuesday. No big deal, it just set off a panic alarm that almost had me packing the Toshiba 4700 back up in the box and on its way back to the store.
  5. MatthewH
    MatthewH Agent
    Dec 20, 2000
    33
    I noticed the dropouts also. I had just purchased a Toshiba
    3750 less than a week ago and had only played 2 or 3 disks before watching POTA. I have only watched about half of the movie but I noticed 6 or 7 dropouts within this period of time. I had no problems on the other disks that I watched. I have my 3750 hooked up to an Integra 7.1, can't advise if the dropouts exsist on the Dolby Digital soundtrack. Just my two cents.
  6. Paul E. Fox II
    Paul E. Fox II Second Unit
    Oct 5, 1998
    354
    I haven't heard any drop-outs yet on my Toshiba SD3109, but when I selected the DTS track from the language selections menu...the disc locked up tight. I had to hit "Stop" then "Play" to get it going again (it was the DTS track when it resumed play though).
  7. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    No dts dropouts on my JVC XV-F80BK/Sony 333es Receiver.
  8. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    Not a single dropout on Panny RV-31/Onkyo 595.
  9. Robert G
    Robert G Stunt Coordinator
    Dec 2, 2000
    191
    No dropouts using my HK DVD50.
  10. John C
    John C Stunt Coordinator
    Mar 3, 2000
    82
    Not to worry, folks. Those of you with sound dropouts don't have defective DTS tracks on your discs. However, there's not much you can do to fix the problem without buying a new DVD player. I have the same problem with my Planet of the Apes disc. There are problems with some DVD players "hiccuping" and dropping the DTS audio for a split second when seamlessly branched, or in the case of POTA, enhanced extras can be activated. I have a Toshiba SD-1200 and T2 has the same audio problem in the exact same spots if watching the movie from beginning to end where seamlessly branched material is inserted. I'm guessing that the extra data size of the DTS track being read on the fly along with data for seamless branching points and enhanced material cause some players to be unable to process all the data for a split second, thus dropping the audio. Of course, switching to the Dolby 5.1 track generates no dropouts, so that is the track to use if annoyed by these occasional hiccups.
  11. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,276
    7
    Steven Simon
    This is completely a hardware related issue. This problem will stem from your reciever or dvd players....
    You can try using another digital input on your reciever. This might do the trick.
  12. Brian OK
    Brian OK Supporting Actor
    Aug 29, 2000
    550
    No dropout on Panny RV80.
  13. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    No problems with Toshiba 3108
  14. Paul Anthony
    Paul Anthony Stunt Coordinator
    Jun 30, 1997
    169
    I haven't had the chance to play my copy of POTA, but I have experienced DTS drop outs on "Apollo 13" and "Dragonheart" on my Pioneer DVL-919.
  15. Kwang Suh
    Kwang Suh Supporting Actor
    Sep 4, 1999
    849
    No problem on my 3750. Worked great, and less filling.
  16. MattGuyOR
    MattGuyOR Stunt Coordinator
    Jul 31, 2001
    114
    T2 and POTA dropouts on my cheap Toshiba 1700. Any on the Panny RP-91? I'm buying one of those soon.
  17. WilliamG
    WilliamG Supporting Actor
    Aug 6, 2001
    510
    ... or are there any on the Panasonic RP-56? I'm waiting on "Planet .." as a rebate from buying the player. (And, no, I didn't buy it BECAUSE of the rebate!)
  18. Leon Liew
    Leon Liew Stunt Coordinator
    Oct 23, 2001
    234
    No drop-outs with my Pioneer 525 cum Onkyo 676. Their
    interaction is flawless.
  19. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    7
    Ron
    No dropouts with my JVC-XVS60.
    Peace Out~[​IMG]
  20. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    no drop out on my Pioneer DV-525 and Pioneer VSX-710S
