Poster Frames
Discussion in 'After Hours Lounge (Off Topic)' started by Mark Fitzsimmons, May 3, 2003.
  1. Mark Fitzsimmons
    Mark Fitzsimmons Supporting Actor
    Aug 18, 2001
    539
    I'm looking to pick up a 27x40 poster frame or two. Where do you guys order your frames? Where can I get the best price?
  2. Jason_Els
    Jason_Els Screenwriter
    Feb 22, 2001
    1,096
    I get mine done by a local framer who uses archive quality mats and anti-UV plexiglass. It costs somewhat more but keeps the posters in the best possible shape and I can choose any frame I think goes best with the poster. Shipping on frames can be expensive and hazardous due to their size and delicacy.
    I got my Lord of the Rings: Fellowship of the Ring bus shelter poster (48x72) framed this way. Had to borrow my grandfather's convertible to get it home but I'm very glad I had it professionally done until I can find a lightbox big enough to really show it off.
  3. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    There have been a bunch of discussions about poster frames in the Home Theater Interiors section of the HTF. I used to get mine at Suncoast, until all of the Suncoasts near me were closed by Best Buy. Michael's craft store carries the same brand of frame. I'll be heading there to buy 5 (yikes, that's gonna hurt the wallet!) tomorrow.
  4. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    Wal mart sells a pretty decent aluminum colored one for 14.00.
    buyt you may want better
  5. Jim_F
    Jim_F Screenwriter
    May 15, 2000
    1,077
    I've used a local art supply and ShowOff Displays. The local shop did a nice job, but it was pretty expensive. ShowOff has an entry level of about $50 which is a pretty nice frame. I bought 2 of them.
    [​IMG]
  6. Mark Fitzsimmons
    Aug 18, 2001
    539
    What size do you suggest, 27x40 or 27x41
    Most posters I have looked at say "approx. 27x40"
    I'm afraid these wont fit in a 27x40 frame and I'll be stuck..
  7. Jim_F
    Jim_F Screenwriter
    May 15, 2000
    1,077
    The poster on the left was a little under 27"x40", so a strip of black paper filled in the top virtually invisibly. The one on the right was a tad over, but I was able to fold the edge under without concealing any of the graphics.
    This was fine with me, since they're both fairly inexpensive repros. If I were using collectable posters, no doubt I'd go with custom framing all the way.
  8. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    suncoast sells 27x40 occasionally.
    I ordered a custom cut frame from www.americanframe.com or something like that for 16 bucks and got the glass cut locally at a crafts place that does framing.
  9. Randy Tennison
    Randy Tennison Screenwriter
    Jan 5, 1999
    1,099
    Randy
    I went to Hobby Lobby (or Michaels), and bought the modular frames. You buy the top and bottom and then the sides to the correct size, and assemble yourself. I then have the store cut a piece of glass and foam core backing to size. Total price about $25.00.
  10. Scott DeToffol
    Scott DeToffol Stunt Coordinator
    Oct 25, 2000
    241
