Possible stupid question about Speaker watt handling
Discussion in 'Archived Threads 2001-2004' started by Edwin_H, Feb 21, 2003.
  1. Edwin_H
    Edwin_H Stunt Coordinator
    Jan 4, 2003
    230
    This may be a stupid question, but I don't know all there is to know about HT, so here we go.
    I have Mirage FRX Rears in my setup, and if I were to get an amp that is rated at 140 watts per channel(Parasound 1205), would that overload the FRXs as Mirage says their power handling only goes up to about 90 watts i think? Or would they be ok? Just curious. Thanks.
  2. Khoa Tran
    Khoa Tran Supporting Actor
    Oct 23, 2002
    569
    you'll be ok, actually it's better to overpower speakers rather then under power them =)
  3. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
    More times than not, it is underpowering your speakers that will blow them (distortion)or produce unwanted musical results. With your present combination, you should be able to hear everything that your speakers have to offer. That is if your room and source player are up to snuff but that's another story and another thread.
    Good Luck.
