Javier_Huerta
- Mar 9, 2002
Hi all!
Well, I finally managed to make a box for my system. It'll be an IB using 4 12" DVC drivers.
As for the room, it's still in the remodeling stage. That said, I have a serious issue with the IB's placement.
Originally, the room had a slanted ceiling and it was a bit irregular. I'm turning it into a rectangle with the adequate proportions to evenly space out nodal modes.
The outside of it, though, will stay the same to minimize cost. So I figured out, if the slanted ceiling stays, and I build a false one out of wire mesh and concrete (in thin layers) I could easily have the acoustical space I needed. Bad thing is, the false ceiling *won't* be able to support the IB manifold. It's simply too heavy.
So I'm looking for some other placement options.... or innovative ideas. The only one that comes to mind is, "connecting" the manifolds' output to the acoustical space via PVC pipes or something. That way, the subwoofer cube could be on the floor, and a couple of 6" painted PVC pipes would connect its output to the space in the ceiling. Would this behave as a true IB, or would it exhibit irregular frequency response, because of the resonance introduced by the pipes?
Thanks for your ideas!
