Possible burn-in?
Discussion in 'Displays' started by Don Keegan, Jul 13, 2006.
  1. Don Keegan
    Don Keegan Agent
    Aug 16, 2003
    39
    I have a 55'' mits rptv 3 yrs old i noticed i now have a color change to my set where the black bars on the side would be the color of the picture is lighter and the middle looks like a yellow tint Help???
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Burn in ... put up a white field and see if there is a distinct change on both sides ...
    No repair solution short of replacing the CRTs.
    Watching in 16:9 mode from now on may reduce the intensity over time.
    Regards
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    as said, check uniformity with a white field at various %.
    Have you been running the set at the original settings? If so, quite possible you have burn in. That's why one calibrates a display and significantly lowers white level.
  4. Don Keegan
    Don Keegan Agent
    Aug 16, 2003
    39
    Thanks for reply, i 99% of the time watch in 16:9 streched if i have to because i've know about burn-in since before owning tv i also set bthe tv utilizing set up dvd to best settings can it be something else???
