Chris PC
- May 12, 2001
Executive Summary: No matter how I have tried to run my sealed subwoofer with my ported front tower speakers, I don't like the resulting bass sound when playing music. Should I try a ported subwoofer?
The reason I ask this is because I noticed that PSB and Mirage (who's former top-of-the-line subs used to be sealed designs) and are now making more and more higher end ported subwoofers, not to mention the countless other companies who make ported subwoofers, and I wonder if I'd like a ported subwoofer instead of my Mirage BPS-400, or, should I try harder to get things in my setup to work better?
Ok, so I have talked about the differences (real or imagined by me) between ported and sealed speaker and subwoofer designs on here before. This is not about one vs the other, but rather, it's about matching a pair of ported tower speakers with very nice low bass sound with a sealed subwoofer. It doesn't sound quite as good as the towers alone. Although I do hear some deeper bass, the good qualities of the bass sound of the tower alone often seems lost when I try to blend the sub. I have tried all sorts of ways. Source Direct playing the towers full range and letting the subwoofer use the front left and right pre-outs and it's own 50hz crossover and/or using the receivers crossover.
I am wondering if it is possible that a ported subwoofer could blend better with my ported speakers. I have a pair of PSB Image T65 towers which are ported and go down to around 30 hz, and when I play music, I am pretty sure I do hear this fairly deep bass extention (deep for a tower speaker rather than a sub). Obviously the tower cannot go much deeper than 25-30 hz at the same volume as a subwoofer can, so I often want to get even more extension. My subwoofer is a Mirage BPS-400 and it's sealed. I have bought a Behringer Feedback Destroyer and plan to try and tame the subwoofer. My room is rather small and somewhat square-ish. The bass from the speakers sound good, but the bass from the subwoofer isn't always what I'd like. For movies, it sounds pretty good, but I have never been able to blend the subwoofer and the speakers to my satisfaction for music. It's a little complicated because in order to get the best bass from my towers I must run Source Direct (full range) so that leaves out the option of using my receivers crossover, which is a high 100 hz anyhow, at least in terms of the best quality of sound.
I will try to EQ the subwoofer better, and I hope to move to a receiver that has at least an 80 hz crossover, or perhaps use an outboard crossover, but I often wonder if the sealed sub and the ported subwoofer are not blending because the character of their bass sounds are mis-matched. Perhaps the sound from the different speaker designs are not blending because their phase and timing is out of whack.
I still want to try to somehow blend a subwoofer with my speakers while allowing the towers to play full range, because their low end sounds good, but I wonder how I should go about it. I was thinking I could use an EQ and/or crossover to get the best out of a subwoofer when I try to blend this way, trying to prevent the subwoofer from interfering or muddying up the bass that the tower is playing but, is there any point in considering a ported subwoofer design in my setup? PSB and Mirage, SVS and countless others make what seem like very good ported subwoofers.
Any thoughts?
Any thoughts?
