Chris-C
- Dec 7, 1998
HI Gang.....long time;
Any thoughts on why my portable player's battery will not charge???
Is it possible that if you let the battery totally run down-you cannot recharge it?
Doesn't seem like this would be the case,and its an internal issue,but it did recharge when I first got it-but now it won't.
Player is a Toshiba 1200.
Just wanted to throw it out here before I send it in or whatever.
If I buy a new battery,and it won't recharge then its a circuit problem,and I wasted money on a new battery.
The original battery is not that old,and was never used very much-so it shouldn't be worn out.
CC Rider
CC Rider
