Port tube length question:
Discussion in 'Home Theater Projects' started by Eric Ha, Jan 25, 2005.
  1. Eric Ha
    Eric Ha Stunt Coordinator
    Sep 27, 2004
    146
    I glued my 3" port tubes into the cabinets on my Adire 281's last night. Now I see that they may be 1.5" too long. I didn't measure the flare for total length but should have. What difference will this make? Is it worth pulling them out and starting over?
  2. Jason Fulton
    Jason Fulton Agent
    Dec 14, 2004
    27
    It will lower the tuning frequency. How much depends on a lot of other variables, if its going to be very difficult to correct listen to them first, see if they sound good to you, if you aren't impressed go hack away.
  3. Eric Ha
    Sep 27, 2004
    146
    Thanks. Actually, according to the Precision Port Calculator, the length that they are at is closer than what Adire recommends. I'm going to listen to them with the front baffles clamped on. Like you said, if it's no good, I'll rip 'em out.
