Port question for 85 Liter Shiva
Discussion in 'Home Theater Projects' started by keoni, Feb 25, 2004.
  1. keoni
    keoni Agent
    Jan 9, 2004
    43
    My 85 L cabinet is vented and I want to recess the driver. Can I double up the baffle thickness and mount the port on the outside without having to change the length of the port? Thanks.
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    It should not be an issue. However, you will be taking away from the inside volume by "doubling" up on the bottom section of MDF. Plus, when you do this, you'll have to shorten the braces by 3/4" to accomodate the extra piece of wood. But, it's not a bad idea.
  3. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    Not if the extra piece of MDF is attached "outside" of the box. Making it 3/4" taller, rather than recessing it 3/4 into the box. He'd actually gain a small amount of volume this way since he's effectively pulling the port out of the box another 3/4", but I think it would be negligible.
  4. keoni
    keoni Agent
    Jan 9, 2004
    43
    Yes this is actually what I am doing. So it wont make much difference then. Thanks for both of your replies.
