Port placement for a diy sub?
Discussion in 'Home Theater Projects' started by JeffPhill, Dec 20, 2003.
  1. JeffPhill
    JeffPhill Agent
    Dec 7, 2003
    28
    Aside from being a certain distance from a wall, brace or sub, and the end being a certain distance from a wall, etc..., does it matter where a port is placed. Should it be installed on the same plane as the subwoofer or can it be on any plane. I am considering a downfiring design (similar to the SVS), and by using a 4" port" I will most likely have the port facing down or out the top to meet the length requirements. Would it be better, in a downfire design, to have the port on one of the sides (front, right, or left) like the SVS' do? Thanks.
  2. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    No, it doesn't really make a difference. Whatever satisfies best the other requirements you already mentioned as well as appearance.
