port placement and SPL (1 Viewer)
KaronnyF
If you place your port on the side, top, or back, instead of directly facing the audience , will you lose SPL produced by the port when the subwoofer is used outside(no walls,etc nearby) , because it isnt facing you directly?
Dave Milne
No.
Since the wavelengths at subwoofer frequences are much larger than any box dimension, output is omnidirectional. Put the port anywhere you like.
Brasspineapple
