Port location -- effects on sound
Discussion in 'Archived Threads 2001-2004' started by Marshall Sander, Mar 25, 2002.
  1. Marshall Sander
    Marshall Sander Stunt Coordinator
    Mar 1, 2002
    71
    I am no audiophile, but I have been doing a lot of reasearch to get into a quality system that sounds good in my room.
    Instead of getting in-wall speakers, I feel that my money is better spent on building a niche in my wall and placing a bookshelf speaker inside the niche and then just making some sort of framed grill covering over the hole in the wall.
    My question is: The niche will be about HxWxD 13x9x??.
    How deep should it be?
    If I get a rear ported speaker, will the sound get boomy because it is in the enclosed niche?
    Should I instead look for front ported or no port (do they exist) speakers?
    Thanks for your help.
  2. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
  3. Marshall Sander
    Mar 1, 2002
    71
    I have listened to SpeakerCraft, PSB and Definitive Technology in-wall speakers.
    I don't think that in-walls all sound bad. Its just seems that I have to spend about $600-800 for in-wall speakers that sound as good as $400 bookshelf speakers.
    I'm now thinking about the Def Tech Studio Monitor 350 or 450, or the Paradigm Reference Studio 20.
  4. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    Klipsch makes some really nice in wall speakers called the "contractor" line, available with Synergy or Reference drivers.
  5. Paul_Dunlop
    Paul_Dunlop Second Unit
    Nov 28, 2001
    318
    Hi
    The niche idea is fine, but don't get a rear ported speakers - there are front ported speakers that will eliminate any port issues.
    Some speakers have Port plugs, but i would think that this is a workaround, not a solution.
    Speaker list
    http://www.psbspeakers.com/s/ImageSeries.html#Image1B
    Take it easy
    Paul
